Will not start
DCADAM
  • 1990 FORD F-450
  • 100,000 MILES
Last fall I changed the cab. I went with the same year however the truck was an automatic tranny. New cab was off a standard tranny. The wiring harnesses hooked up fine. I have depressed the clutch pedal switch. The truck turns over. I have spark at plugs. I have gas to engine. However it will not fire. The oil pressure goes up on gauge as I crank engine. I am stumped.
Do you
have the same problem?
Monday, May 20th, 2013 AT 3:25 PM
  • EXPERT
What is the fuel pressure?
Monday, May 20th, 2013 AT 7:36 PM
Recommended Guides
