Will not idle on its own had to adjusted throttle cable
KYLELEVERENCE
  • 1996 DODGE STEALTH
  • 100,000 MILES
First car would when hot go through 1st and 2nd gear fine then at the end of 3rd it would stumble. Now the car stopped idling and jolts when letting of the gas when warmed up and has low idle and running rough
Do you
have the same problem?
Friday, July 26th, 2013 AT 1:57 PM
HMAC300
  • EXPERT
Scan for codes and check fuel pressure first.
Saturday, July 27th, 2013 AT 11:01 AM
Recommended Guides
