Camshaft sensor location please?
TRENTWOOD JORDAN
  • 2007 GMC YUKON
Location of the camshaft position sensor on 5.3 ltr engine on the yukon.
Monday, September 27th, 2010 AT 6:44 PM
See location @ #7 on diagram below:
https://www.2carpros.com/forum/automotive_pictures/12900_c_32.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_c1_51.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_c2_44.jpg
Monday, April 1st, 2019 AT 5:50 PM
CAREBEAR65COMPLETE
  • 2002 GMC YUKON
  • 5.3L
  • V8
  • 154,000 MILES
Customer states that after vehicle warms up and he is driving it on the road it stalls out. Also states that he has to let it cool down and it is easy to restart. Customer wants me to replace the camshaft and crankshaft sensors. How much should I charge as an outside source?
Friday, June 19th, 2020 AT 1:32 PM (Merged)
HMAC300
  • 48,601 POSTS
Camshft sensor is at top rear of engine crank sensor is by starter. but check fuel pressure with a gauge it may not be getting to spec auto parts rent gauge.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,882 POSTS
The Camshaft Position (CMP) Sensor (5.3L VIN T) is located on the center bottom of the front of the engine. Here is the location of the crankshaft sensor which it is more likely to be. You should charge about an 1.5 hours for both, plus parts. Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
TOUCHDOWN2ND
So who is right? And Ken your image doesn't work.
Wednesday, September 28th, 2022 AT 4:47 PM
KEN L
  • 42,882 POSTS
Please refresh the page, it should work, it is a bug the site has.
Wednesday, September 28th, 2022 AT 7:23 PM
JUSTINT09
What about on an 2014 Tahoe?
Wednesday, February 15th, 2023 AT 6:02 PM
KEN L
  • 42,882 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Thursday, February 16th, 2023 AT 4:57 PM
