Wheel bearings
CONNIE TORRES
  • 2000 FORD FOCUS
  • 178,000 MILES
Rear wheel bearings wearing out faster than normal.
Do you
have the same problem?
Saturday, January 21st, 2017 AT 10:29 AM
STEVE W.
  • EXPERT
What do you consider "faster than normal"?
How are the tires wearing? If you have abnormal tire wear you will want to have the rear end checked for alignment/damaged parts.
If the issue is simply that the bearings are failing it could be that they are being installed incorrectly, that the bearings are low quality or that the vehicle is overloaded.
Saturday, January 21st, 2017 AT 11:45 AM
Recommended Guides
