Compatible transmissons?
KATIEISREBEL
  • 1998 SUBARU FORESTER
  • 2.5L
  • 4WD
  • MANUAL
  • 207,000 MILES
I know that cars are compatible parts wise with certain other makes/ models sometimes and I was wondering if the vehicle listed above manual transmission had any other compatible models/makes for things like the ignition cylinder and door lock cylinders?
Do you
have the same problem?
Wednesday, March 15th, 2023 AT 9:34 AM
KEN L
  • ADMIN
The 1998 Subaru Forester is based on the same platform as the 1993-2001 Subaru Impreza, which means that some parts may be interchangeable between these two models. Here are a few compatible parts that you may want to consider:
Ignition cylinder: The ignition cylinder for a 1998 Subaru Forester should be compatible with the 1993-2001 Subaru Impreza. You can check with your local auto parts store or online retailers to see if there are any specific part numbers that are interchangeable between the two models.
Door lock cylinders: The door lock cylinders for a 1998 Subaru Forester should also be compatible with the 1993-2001 Subaru Impreza. Again, you can check with your local auto parts store or online retailers to see if there are any specific part numbers that are interchangeable between the two models.
Other parts: In addition to the ignition cylinder and door lock cylinders, there may be other parts that are interchangeable between the 1998 Subaru Forester and the 1993-2001 Subaru Impreza. For example, some suspension components, engine parts, and interior components may be compatible. However, it's important to note that not all parts will be interchangeable, so it's always a good idea to check with a qualified mechanic or auto parts specialist before purchasing or installing any parts.
Wednesday, March 15th, 2023 AT 4:52 PM
