HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Drivetrain
Transmission
Pan
Replace/Remove
What is this little white thing floating around in the bottom of the transmission pan?
TEEMONEY
MEMBER
2008 FORD F-150
5.4L
V8
2WD
AUTOMATIC
257,000 MILES
I was changing the transmission fluid and when I removed the pan, it was this little white thing floating around in the rest of the fluid in the pan.
Do you
have the same problem?
Sunday, August 14th, 2022 AT 6:30 AM
SQM
EXPERT
Not sure if you tried to upload the picture, but we cannot see any attachment on your post.
Please re-upload the picture.
SPONSORED LINKS
Sunday, August 14th, 2022 AT 10:37 AM
Please
login
or
register
to post a reply.
Related Transmission Pan Replace/Remove Content
1995 Ford F150 Truck Wont Move
I Drove My Truck To The Mechanics Garage And Needed My Transmission Pan Gasket Replaced So He Said Do The Filter As Well So I Did And They...
Asked by
shanecaines
1995
FORD F-150
Wont Let It Shift Out Of Park
Brake Lights Not Coming On When I Push Brake Pedal. Wont Let It Shift Out Of Park. Changed Brake Pedal Position Switch Checked All Fuses....
Asked by
mr.eldridge
12 IMAGES
2009
FORD F-150
Stick Shift Is Very Loose Even When In Gear
Recently Had Slave And Master Replaced, Now Stick Shift Is Very Loose Even When In Gear, Wondering If Trans Going Out?
Asked by
medaide63
2 IMAGES
2003
FORD F-150
1998 Ford F150 Will Not Come Out Of Park
I Drove The Truck, Parked It And Put The Truck In Park. When I Went Back To Use The Truck It Will Crank Up But Will Not Come Out Of Park...
Asked by
question1
1998
FORD F-150
Rear Drive Shaft Seal Is Leaking
Sirs, I Have A 1994 Ford F150 V6 4.9 Engine 4x4 With 110000 Miles On It The Rear Drive Shaft Seal Is Leakinng How Can I Fix It. And Is It A...
Asked by
micshirey
1 ANSWER
FORD F-150
VIEW MORE
SPONSORED LINKS
How to Service a Manual Transmission - EASY!
Service a Transmission Ford F-150
Transmission Service
Online car repair manuals
