Water pump only comes half way out
FMOODY
  • 1995 NISSAN MAXIMA
  • 3.0L
  • V6
  • FWD
  • 196,000 MILES
After removing the 3 bolts started removing the pump it comes out about 1/2" to 3/4" on an inch then stops checked mounting bracket it appears to be in correct placement. Put bolts in and tried to pry it out it seem loose but won't come out. Chain is off the sprocket
Do you
have the same problem?
Wednesday, July 8th, 2015 AT 10:41 AM
KHLOW2008
  • EXPERT
You need to pry hard to get the pump off.
Wednesday, July 8th, 2015 AT 11:54 AM
Recommended Guides
