Warning Sound when a gear is selected
KOKO.121
  • 2004 FORD FIESTA
I have a ford fiesta 2004 in my garage. The problem is when u turn on the car and choose a gear (drive, reverse) a warning beep starts when u release the brake pedal. But whenever you're pressing the brake pedal no warning beep is found. So is there any solution? Btw no fault codes is found
Do you
have the same problem?
Thursday, April 25th, 2013 AT 6:25 AM
  • EXPERT
Check all your bulbs
Friday, May 10th, 2013 AT 7:36 PM
Recommended Guides
