2001 Volvo V40 Driver side window will not come up.
VOLVO4
  • 2001 VOLVO V40
  • 4 CYL
  • FWD
  • 10,000 MILES
The window has no problem going down. But when coming up it stops at the bottom and sounds like it's grinding something. Then I can assist it by pulling up on the window and it will go half way and make the same sound, and then after one more assist it makes it to the top and stops with about a quarter inch crack. The window also slides forward. It's rainy season and looking for something I can do if at all possible.
Do you
have the same problem?
Tuesday, October 13th, 2009 AT 8:09 PM
JIS001
  • EXPERT
You will need to replace the window regulator.
Wednesday, October 14th, 2009 AT 1:10 AM
Recommended Guides
