2001 Volvo S60 Fuel gauge in-accurate after batter change
67RUDY
  • 2001 VOLVO S60
  • 4 CYL
  • FWD
  • 105,000 MILES
Battery died and replaced. Now the fuel gauge won't read above 1/2 full even when actually full.
Does go down as gas is used, and will go back up to 1/2 when filled up. Is there some kind of re-set required after batter replacement?
Do you
have the same problem?
Friday, July 24th, 2009 AT 4:37 PM
JIS001
  • EXPERT
This applies only if you have a plastic gas tank. You may want to look at the fuel level sender on the left side of the gas tank. To access you need to remove the rear bench and remove the 10mm nuts to remove cover. Inspect wiring harness and make sure to check to see that nothing was unplugged. Anything beyond that you should take in to a shop for further diagnosing.
Sunday, July 26th, 2009 AT 10:49 PM
Recommended Guides
