Fuel pump relay location
ROBBRICHARD
  • 1994 VOLVO 940
  • 4 CYL
1994 volvo 940 wagon where is the fuel pump relay replaced fuel pump, fuses are good still no fuel?
Do you
have the same problem?
Sunday, May 22nd, 2011 AT 8:06 PM
WRENCHTECH
  • 20,758 POSTS
The fuel pump relay is near the center oft he dash here is a guide to help you test it and the location below.
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Sunday, May 22nd, 2011 AT 8:44 PM
MANOSMITH
  • 1995 VOLVO 940
  • 4 CYL
  • 94,000 MILES
The check engine light came on and when I accelerate the gas pedal it hesitate to move and the engine dies off. Got it started again and it does the same thing couple of times. I have replaced the fuel pump, fuel filter, air filter and fuel pump relay. What else would have gone wrong or bad. Please advise as I am worried it may happen again while I am on H'ways with small children on board.
Thank you
Saturday, October 27th, 2018 AT 5:37 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Code indicates fault in Mass Air Flow Meter or Fuel Injection Main Relay
