2005 Volkswagen Passat Engine management light
TAHIRTAZO
  • 2005 VOLKSWAGEN PASSAT
  • 4 CYL
  • FWD
  • MANUAL
  • 125,000 MILES
My car is 100bhp it got a problem I am not sure of, it's engine management light stays on for a while and sometime it disapers, doesn't make any difference on car perfomance gives caution as emmissions workshop.I 've checked Egr valve it's clean n working. What problem that can be, also a noise from dash comes when car is start or ignition is on like something is broken. Can u suggest what problem it cou
ld be. Thank you
Do you
have the same problem?
Friday, July 17th, 2009 AT 11:42 AM
STEVEW84
What is the code? Find out then repost.
Friday, July 17th, 2009 AT 7:43 PM
Recommended Guides
