1999 Volkswagen Jetta Transmission Fluid Change
RYANQ
  • 1999 VOLKSWAGEN JETTA
  • 4 CYL
  • FWD
  • 12,800 MILES
I've got a small leak in the trans which requires me to add fluid every 4-6 months or so. I've been using the G 052 162 A2 from the dealership. I've bought something form the local O'Reilly auto parts store that is compatible with the VW LT71141 trans.
As I understand it these two fluids are different colors. Is it going to be a problem topping off the existing fluid with a different kind of fluid?
Do you
have the same problem?
Thursday, July 16th, 2009 AT 5:52 PM
STEVEW84
As long it is compatible it will be fine.
Friday, July 17th, 2009 AT 12:16 PM
Recommended Guides
