1996 Volkswagen Jetta wont turn over
NEWMECHA
  • 1996 VOLKSWAGEN JETTA
  • 4 CYL
  • FWD
  • MANUAL
  • 180,000 MILES
So my Jetta wont turn over I checked the battery and its working fine
Do you
have the same problem?
Tuesday, September 21st, 2010 AT 10:35 PM
Is it cranking over and refuses to start or just won't crank at all/nothing when you hit the key to start position?
Tuesday, September 21st, 2010 AT 10:58 PM
NEWMECHA
It wont crank there's nothing at all, with the key on the on position
Wednesday, September 22nd, 2010 AT 1:00 AM
If nothing is On when key at run-start by checking all fusible links/fuses and then ignition switch
Wednesday, September 22nd, 2010 AT 3:57 AM
NEWMECHA
When I turn on the ignition I hear a continues click on the throttle
Saturday, September 25th, 2010 AT 8:57 PM
Recommended Guides
