The alarm module is behind the instrument panel (behind & below the headlight switch).
For Testing Purposes:
You can disconnect the 2 harness plugs that are attached to it (to stop the drain and so that you can do pin-out tests).
The engine will not crank when the two harness plugs are disconnected!
For more information (pin-out tests & which wires to bridge so your starter will work). I will wait for your reply.
Thomas
Tuesday, December 20th, 2016 AT 10:28 AM
(Merged)
