1999 Volkswagen Golf oil loss
PORTUGAL
  • 1999 VOLKSWAGEN GOLF
  • 4 CYL
  • FWD
  • MANUAL
  • 97,000 MILES
Oil lossat a fast rate. Lots of black soot coming out of tail pipe. Whats the problem? How can it be repaired?
Do you
have the same problem?
Monday, July 27th, 2009 AT 6:24 AM
DUBTECH
What do you consider a "fast rate"?
VW officially feels that 1 quart per 1000 miles is a normal rate of consumption.
Changing the oil at the proper intervals and using thicker oil can help.
If it's more than 1 quart per 1000 miles, the oil is changed often, and you are already using a thick oil you may need to have a compression or leak down test done to pinpoint the problem.
Monday, July 27th, 2009 AT 10:30 PM
Recommended Guides
