1999 Volkswagen Golf misfiring / running on 2 cilenders at
210 GTI TURBO
  • 1999 VOLKSWAGEN GOLF
  • 4 CYL
  • FWD
  • MANUAL
  • 10,800 MILES
I have a mk4 golf gti turbo when I bought it 1 of the coil packs was down so I replaced it and it was still doing it so I replaced the other 3 coil packs and the spark plugs I am still having the same problem. If I put my foot down it clears out but dosent feel as powerfull as it should be through gears then when I let of the throtle it goes lumpy again?
Do you
have the same problem?
Sunday, February 15th, 2009 AT 7:17 AM
VLADGEISER
1.8T? What grade fuel are you running as if it is the turbo model you need to run a minimum of 87 preferably 91 or above as the boost will cause ignition retarding and loss of power if it starts getting detonation due to low octane. Speaking of witch see if you can find someone to test the ignition module, a Checker or Advance Auto would be worth calling.
Wednesday, March 4th, 2009 AT 2:09 AM
Recommended Guides
