Thermostat location
WMBULLY
  • 2001 VOLKSWAGEN BEETLE
Where is the thermostat located on my car?
Sunday, April 25th, 2010 AT 3:09 PM
Looks to be on the side of the engine, about half way down
Read the guide below on changing a thermostat, not vehicle specific but will give you an idea of what you are doing
See the diagram below for location/components of the thermostat and housing
Monday, April 26th, 2010 AT 4:38 PM
PDERRY
  • 2000 VOLKSWAGEN BEETLE
  • 2.0L
  • V8
  • TURBO
I need to replace the thermostat on a 2000 2.0 turbo beetle. However, I can't seem to find the thermostat location. Thanks
Saturday, November 10th, 2018 AT 7:44 AM (Merged)
JIS001
  • 3,408 POSTS
You need to remove the alternator. Thermostat housing will be behind it. Attached picture. Why are you replacing the thermostat?
TANYAMARIE1983
  • 2002 VOLKSWAGEN BEETLE
  • 4 CYL
  • 104,000 MILES
My dad change the thermostat and my car still leaks.
Why
OMARRUFO
  • 11 POSTS
I just changed mine as well. You gotta be careful when you replace that thermostat stay in place until housing makes contact with engine block. Since nothing really holds thermostat and o-ring in place, if it moves out of place, it may not seal properly.
  • 108,128 POSTS
Replacing the thermostat isn't too difficult to do. Make sure you have a place to put the old coolant after it's drained. You don't want any animals drinking it.
To get you started, here is a link that explains how in general one is replaced. You can use this as a more detailed guide when doing the job. The directions specific to your vehicle are attached in the pics below.
If you look at the pics below, the location of the thermostat is indicated.
I hope this helps. Let me know if you have other questions.
Friday, October 1st, 2021 AT 9:37 PM
