Vents
JBC2579
  • 2006 FORD F-250
  • 173,890 MILES
Vents default to defrost. Vacuum pump constanly runs. But can switch to 4x4 and vents change to front vents for few mins. Unlpuged hose comeing off vacuum canister and put finger over hole and it shut off. Put back on and unplugged the two vacuum lines from canister and plugged with finger and pump never shut off. Just need a direction to head to fix this problem
Do you
have the same problem?
Sunday, May 26th, 2013 AT 4:47 PM
HMAC300
  • EXPERT
Check for a vacuum leak it may be the cannister
Monday, May 27th, 2013 AT 6:07 AM
Recommended Guides
