1997 Other Vauxhall Models Frontera SPORT 4WD assembly prob
DINO89
  • 1997 VAUXHALL
Transmission problem
1997 Other Vauxhall Models Four Wheel Drive Manual 45000 miles
hi
stripped and replaced front wheel bearing on 4wd frontera with auto engage 4wd system, trouble is not sure what position the clutch for the 4wd should be in when I reassemble it can anyone help, the haynes manual says the lug should line up with a mark on the clutch but when I took it apart the lug was right at the bottom of the slot whats correct?
thanks
Do you
have the same problem?
Saturday, March 15th, 2008 AT 2:32 PM
DAVE H
  • EXPERT
I would follow the instructions in the manual !
Saturday, September 12th, 2009 AT 5:27 AM
Recommended Guides
