2002 Vauxhall Omega ems fault staying on
E.WRIGHT
  • 2002 VAUXHALL OMEGA
  • 4 CYL
  • 51,000 MILES
My car (above) constantly shows the ems fault light but nothing appears to be wrong. I have taken it to local agent who checked it fully serviced it and the cam belt was hanged The fault code says it has a fuelling fault but emissions are ok, fuel consumption iis normal 25-30 mpg. (40mpg on motorway) The only small clue I have is that when initially starting from cold the engine seems to be over rich this seems more noticeable if I leave the air-con on. However a blip of the throttle and it clears straightaway. Any suggestions as to a possible cause would be appreciated. It is a 2.2lt omega sport with the ecotec 16valve engine
Do you
have the same problem?
Thursday, July 23rd, 2009 AT 5:49 AM
DAVE H
  • EXPERT
Clean/replace the MAF (mass airflow) sensor !
Sunday, July 26th, 2009 AT 6:26 AM
Recommended Guides
