2003 Vauxhall Astra Astra cdti blue smoking
2003 VAUXHALL ASTRA
84,000 MILES • 4 CYL • 2WD • MANUAL
DUCK0025
Hi ive just bought an astra 1.7 CDTI 2003. It was advertised with a turbo fault but i dont think it is. When you start it, it will missfire and produce blue smoke for a few seconds then clear up. But if you give it a rev, will missfire and smoke again for a few seconds. Any ideas?
Aug 28, 2010 at 9:42 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
when an engine smokes a little on start up then clears it is usually a sign that the valve stem seals are worn, but in your case, with the engine running an it is puffing smoke on hitting the throttle, you may have a faulty main turbo oil seal, this will allow oil into the exhaust at the turbo shaft.
mark (mhpautos)
Aug 28, 2010 at 10:39 AM
