1999 Vauxhall Astra wont stay runing when satarted
DARREN THORPE
  • 1999 VAUXHALL ASTRA
  • 4 CYL
  • FWD
  • MANUAL
  • 13,000 MILES
Ive got a vauxhall astra that starts but dont stay running ive cheked the filter and the sender and return pipess to the carb and there fine also the wireing around the carb. Ive also checked the fuses in the car but all fine.
you can put your foot on the gas and start the car it will rev but for a second and then cut out. But the same also happens when you start it with no gas.
can you help thank you
Do you
have the same problem?
Friday, July 24th, 2009 AT 2:12 PM
DAVE H
Sounds like the immoboliser is still activated !
Sunday, July 26th, 2009 AT 6:19 AM
Recommended Guides
