Turns over but will not start
JOSH D
  • 2004 DODGE NEON
  • 2.0L
  • 4 CYL
  • FWD
  • 180,000 MILES
Had problems with alternator and battery I replaced both. The car ran great no issues all the way to a friends house across town. When I got there turned the car off it would not start back up turns over but will not start. Can hear the fuel pump kick on and has great pressure at the fuel rail. Replaced crank sensor and coil pack thinking fire maybe the issue no fuses are blown. Not sure what would make it not start just all of a sudden like it is.
Do you
have the same problem?
Thursday, June 1st, 2017 AT 10:22 PM
CARADIODOC
  • EXPERT
Have you checked for spark? Have you read the diagnostic fault codes? Do you know how to do that yourself? If not, cycle the ignition switch three times from "off" to "run" within five seconds without cranking the engine, leave it in "run", then watch the code numbers show up in the odometer display. Tell me what you find.
Do you have the dual or single-cam engine?
Friday, June 2nd, 2017 AT 10:53 PM
Recommended Guides
