Turning signal left
TJASKA
  • 2001 FORD ESCAPE
  • 3.0L
  • 6 CYL
  • 4WD
  • 139,550 MILES
My turning signal on the left side does not work I checked the fuse that is fine.
The light in the dashboard goes on but does not flash.
As I put on the hazard lights it does flash inside but that is all.
I also checked the flasher fuse that is fine too.
What am I missing.
Do you
have the same problem?
Wednesday, April 13th, 2016 AT 12:37 PM
JIS001
  • EXPERT
Either your flasher has gone bad or you have a bad turn signal switch. Wiggle the turn signal switch around and see if that will make it flash.
Wednesday, April 13th, 2016 AT 4:43 PM
TJASKA
Thank you for replying, Did that and it still won't work.
This means I have to change the switch?
Wednesday, April 13th, 2016 AT 8:39 PM
JIS001
  • EXPERT
If you replaced the flasher and it is doing the same thing then yes, I would recommend a turn signal switch. Have a replaced a couple for the same problem.
Thursday, April 14th, 2016 AT 9:54 AM
Recommended Guides
