Turn signals not working
SARNOLD2426
  • 2004 OLDSMOBILE ALERO
  • 4.6L
  • 6 CYL
  • FWD
  • 140,000 MILES
I have just replaced the hazard switch in it. Now the turn signals will not come on. I have also replace the turn signal controller due to the wiper control arm was broken. So any help would be helpful.
Do you
have the same problem?
Friday, March 10th, 2017 AT 2:23 PM
KHLOW2008
  • EXPERT
Have you checked the fuse for the turn signals?
Are the hazard lights working?
Sunday, March 12th, 2017 AT 1:44 AM
SARNOLD2426
After replacing everything, I later learned that the turn signals have not been working for the past few days prior of me replacing everything. Yes I did check all the fuses and everything check out okay. Also, the hazard switch is working as well. So at this point I am leaning towards that there is a short somewhere in wiring.
Monday, March 13th, 2017 AT 1:16 PM
KEN
  • ADMIN
There is a auto park lamp control relay that looks like it controls the power to the turn signals that could be out, here is a guide and a diagram that can help you get the problem fixed. Also you can check for power and see if you are loosing it somewhere.
and
Please run this test and get back to us so we can continue helping you.
Best, Ken
Thursday, March 16th, 2017 AT 11:40 AM
ANNE4670
2004 Oldsmobile Alero
We have a problem with the turn signal not working at different times (when it is raining or the air conditioner is on and it causes moisture). My husband has checked a few things, but still we would like more advice on how to fix it so we don't have to stick our arm out the window. Can you give a suggestion on what to try?
Thursday, March 16th, 2017 AT 1:08 PM (Merged)
  • EXPERT
When it doesn't work, do you mean it doesn't flash or doesn't work at all?
ANNE4670
Our turn signal does not work at all at iffeerent times
  • EXPERT
If they don't work at all, I would start at the switch in the steering column.
SNUPCAKE
  • 2003 OLDSMOBILE ALERO
  • 76 MILES
I have a 2003 olds alero w 76k miles. Just recently the following things have started happening. The turn signal goes ticka-ticka-ticka when it should shut off. The blower is not working well, it only works on high, and the lighter/outlet thing doesn't work if I plug anything in. Is this a sign that something big is going on or are these little unrelated things.
HMAC300
  • EXPERT
They could be unrelated. Check your fuses for the lighter and body to battery ground for the flasher. You could have a bad flasher as well. For the blower check your resistor, it should be by the blower, see if it is getting and putting power out, it may not be. If it's not getting power check the control head.
  • EXPERT
If the signals are not canceling, chances are the plastic tab that shuts them off when the steering wheel centers is broken. If the blower motor only works on high, chance are either you have a bad blower motor resister or relay. Finally, check for a blown fuse to the lighter. Check to see if there is power to the lighter. There should only be one wire going to it.
TWINKIEDELIGHT05
  • 2002 OLDSMOBILE ALERO
  • 150,000 MILES
When you go to turn on the blinker sometimes they dont' work. But if they don't come on an you turn the fourways on an leave them on while you turn the blinker on an then turn four ways off the blinker will blink. But for some reason now that even though the blinker isn't on the ticking noise that the blinker makes while blinking ticks as if the blinker is on an it isn't. Any solutions
FIXITMR
Try lubing hazzard switch. It interacts with turn signals. Or just replace it? You also may have a bad multi sitch which is your turn signal assembly. Could be wire loose or bent contact, etc.
SIMON10
If you haven't already got the issue fixed, try calling a gm service tech and provide them with your vin number. I have a 2000 that did the same thing and it was recalled so they fixed it for free. It has something to do with bad soldering.
  • 2000 OLDSMOBILE ALERO
  • 130,000 MILES
My alero just had the turn signals outside and the dash indicators suddenly not work. Upon trying to figure out why I noticed my running lights were also not working. Then just as quickly as they stopped working they started working fine again. What is causing this so I can get it fixed asap?
  • EXPERT
Bad connection somewhere. Check all scokets and bulbs.
MALACY0349
  • 2.2L
  • 4 CYL
  • 115,000 MILES
For a while the turn signals would work but one day it stopped working the majority of the time.
Now the turn signals have become irregular in their functioning. Some times they will not come on, other times they will work like they are supposed to and even weirder is quite often a solid hit on the dashboard right above the gauges will bring them back on.
Any ideas?
HMAC300
  • EXPERT
It might be a loose connection at dash, or it jars the hazard switch where your flasher is. Or coincidental
Recommended Guides
