Turn signals
SMOORE4894@AOL.COM
  • 1993 FORD RANGER
  • 4 CYL
  • MANUAL
  • 140,000 MILES
My turn signals stopped working. I changed the flasher that did not work. I got a used switch from the wrecking yard that also didn't work. The emergency flashers work fine. Any suggestions?
Do you
have the same problem?
Wednesday, March 23rd, 2016 AT 2:00 PM
HMAC300
  • EXPERT
Seepic, make sure power is going to t/s switch from flasher and out of switch with arrows. Then check connection of t/s switch for corrosion if it has it clean off what you can then use dielectric grease get at auto parts. For about $2 usually on counter. Tehn check to see if power goes to rear at sockets it may be bad sockets or wiring is shorted between switch and sockets. You can use a test light to check
Wednesday, March 23rd, 2016 AT 4:11 PM
Recommended Guides
