Turn signal and dashboard guages stopped working
SHELLSMITHS7
  • 1995 NISSAN SENTRA
  • 112,000 MILES
95 nissian sentra xe. Noticed when driving that my turn signals, odometer, speedometer, gas, and temp guages stopped working. Then would start working maybe the next two or three times I started the car. This happened about 8 timesin the last 4 months. Now my battery died replaced that. Now signals and guages still don't work and haven't come back on. All otherotherelectrical things work headlights flashers ect. Where to start?
Do you
have the same problem?
Sunday, September 8th, 2013 AT 6:24 PM
  • EXPERT
Make sure all wiring under the dash to the panel are tight and clean. Also, check for weak or damaged body grounds. You may also need to have the BCM checked.
Sunday, September 8th, 2013 AT 6:30 PM
