Trying to remove starter but not enough room to get it out. Is there some secret trick?
ENCHILADEEDA
  • 1990 CHEVROLET S-10
  • 3.5L
  • 6 CYL
  • 4WD
  • MANUAL
We have tried everything! Removed clutch, jacking engine up, and there is NO way to get that starter out! No clearance to make room. At wits end! This is a 1990 4x4 S-10 Blazer. Please, any suggestions that aren't obvious. Have have several good shade tree mechanics look at it and no suggestions. HELLPPPP>>>>
Do you
have the same problem?
Thursday, September 24th, 2015 AT 2:33 PM
ENCHILADEEDA
This is a 4.3 L engine. So frustrated I got confused.
Thursday, September 24th, 2015 AT 2:37 PM
WRENCHTECH
  • EXPERT
STARTER MOTOR REPLACEMENT
Remove or Disconnect
Place the vehicle on a hoist.
Negative battery cable.
Starter Motor Mounting On The 2.5L Engine
Brush end mounting bracket on the 2.5L engine starter motor.
Solenoid wiring. On the 4.3L, raise the vehicle halfway on the hoist, and reach through the right wheel well.
Raise the vehicle.
4 Wheel Drive Vehicles:
Four bolts on the skid plate (if equipped).
Skid plate (if equipped).
Bolts and the two brackets holding the brake line to the crossmember.
Crossmember (three bolts on each side).
Bracket holding the transmission fluid cooler lines to the flywheel housing, brace rod to the flywheel housing and/or the lower flywheel housing if necessary.
All Models:
Two bolts holding the starter to the engine.
Starter and the shim (if present).
Thursday, September 24th, 2015 AT 5:49 PM
ENCHILADEEDA
My son came out, and after much frustration, got the motor mount loose and the engine jacked up enough to get the starter out. There just isn't any room to work on the Blazers. I am going back to Ford next time I buy a vehicle. I never saw anything so hard to work on as that Blazer s10.
Saturday, September 26th, 2015 AT 9:14 AM
ENCHILADEEDA
Thank you, but we finally got it out and replaced yesterday.
Saturday, September 26th, 2015 AT 9:15 AM
WRENCHTECH
  • EXPERT
Don't worry, they all have their tough issues.
Saturday, September 26th, 2015 AT 9:17 AM
Recommended Guides
