Truck wont start unless you hold throtle 1/2 to full down and crank motor excessively
TIM BUCKINGHAM
  • 1992 DODGE DAKOTA
  • 155,000 MILES
After getting engine started, seems to idle but not perfect, try and apply throttle and engine hesitates an trys to die, but will pick up rpms if you feather gas pedal, auto idle motor appears not to be working, could the auto idle motor being bad cause my problems?
Do you
have the same problem?
Monday, July 1st, 2013 AT 3:17 PM
HMAC300
  • EXPERT
Scan for codes and check fuel pressure first
Tuesday, July 2nd, 2013 AT 5:56 AM
Recommended Guides
