Engine will not stay running?
CHAS662
  • 1994 CHEVROLET SILVERADO
  • 5.7L
  • V8
  • RWD
  • 13,000 MILES
C-1500 after engine warms up starts to run rough and shuts off at low rpm. Get code 54 and have tried all the easy possible fixes.
Do you
have the same problem?
Saturday, May 6th, 2017 AT 7:46 PM
HMAC300
  • EXPERT
See picture. fuel pump circuit check the fusible link in picture at battery should be twelve volts both sides. then check ground for pump may be corroded. should be 9-11 PSI. also, check gasket at base of TBI they like to blow out use choke cleaner to check. can be a bad relay, oil pressure switch low oil pressure etc. This guide should help.
https://www.2carpros.com/articles/engine-stalls
Check out the diagrams (Below). Please let us know what you find.
Sunday, May 7th, 2017 AT 8:24 AM
CHAS662
Thanks for the reply.
Monday, May 8th, 2017 AT 1:54 PM
CHAS662
Sorry didn't back to sooner. This started out with me changing map, plugs and wires, dis cap, rotary button. Sense then I have changed egr, fpr and fuse, oil pressure sending unit, iac, tps. At that point it stopped firing so I changed coil pack and still no fire. I don't have a meter and get confused when I try to read one so I'm out of luck there. As you can tell at I only qualify as a shade tree. I do appreciate the help and still at a stand still.
Tuesday, May 9th, 2017 AT 6:32 AM
HMAC300
  • EXPERT
You'll have to check resistance of pickup coil 400-1000 ohm and take ignition module in dist to auto parts they can check it
Tuesday, May 9th, 2017 AT 6:56 AM
CHAS662
Put on a new ignition module. Thanks again for the help. It starts now but it runs rough and sometimes back fires. Test drive and it run so bad it would hardly go. I get code 22 for the tps but I had put a new one on already. I just took it off and used the old round bushing and put new one on. Did I need to do something else?
Wednesday, May 10th, 2017 AT 6:22 AM
HMAC300
  • EXPERT
Did you check vacuum hoses for soft and broken/cracked and for a blown gasket under tbi unit like I said in first reply
Wednesday, May 10th, 2017 AT 6:32 AM
CHAS662
I do not find any bad vacuum hoses or leeks gasket seems to be ok also.
Wednesday, May 10th, 2017 AT 7:21 AM
HMAC300
  • EXPERT
Check your firing order you may have things mixed up there.
Wednesday, May 10th, 2017 AT 12:09 PM
CHAS662
With your help and expert advice we have old truck going down the road smooth. Makes me fell good. Thank You very much. Hope my small donation helps.
Thursday, May 11th, 2017 AT 10:36 AM
KEN
  • ADMIN
Thanks for the donation! It helps to keep the site going!
Cheers! Ken
Saturday, May 13th, 2017 AT 5:34 PM
CSA1
  • 5.7L
  • V8
  • 4WD
  • 275,000 MILES
Lately, truck stalls at stop. Starts right back up & idles fine though. Also stalls randomly at idle.
Truck has new distributor, fuel pump, fuel filter, plug wires, & new wire harness for injectors on TBI. Wondering if it could be fuel pressure regulator in throttle body?
Thursday, September 3rd, 2020 AT 12:46 PM (Merged)
HMAC300
  • EXPERT
Try cleaning with choke cleaner first including iac hole. Then check pressure shold be 9-11 psi if tbi
CSA1
Another odd thing, if it drops below freezing, the truck will not start. Turns over, but wont run
HMAC300
  • EXPERT
Scan for codes is this a tbi or pfi truck? It may not be richening the mix not letting it start when cold.
CSA1
No codes present & it's a TBI
HMAC300
  • EXPERT
Check coolant temp sensor for connection and corrosion on connector, if it is replace the sensor and connector. Check with sensor in vehicle. Se pic
PAUL FARRAR
  • 4.3L
  • V6
  • MANUAL
  • 226,000 MILES
Truck will fire right up, let off the gas it shuts off. Give it too much gas it shuts off. Just replace fuel filter distributor cap and rotor. Was running fine one day then all the sudden boom. Computer shows no code. Code 12 only route number 1 to TDC and distributor pointing right at it. I don't believe it jumped time.
Thursday, September 3rd, 2020 AT 12:47 PM (Merged)
SCGRANTURISMO
  • EXPERT
In the diagrams down below I have included the factory diagnostic troubleshooting guide for Direct Trouble Code 12 for your vehicle. Please go through the guide and do exactly as it says and get back to us with what you are able to find out. We can go from there.
Thanks,
Alex
2CarPros
PAUL FARRAR
Exact same thing. Flashes 12 that's it.
DOCFIXIT
  • EXPERT
Could be a fuel pressure issue or TPS maybe faulty. With no codes check the basics.
