Transmission is not shifting properly
THEROEFAMILY
  • 1985 CADILLAC SEVILLE
  • 4.1L
  • V8
  • 86,365 MILES
I have run trouble code test it give me 19, 27, 39, 52 the first code that come up is -1.8.8 not sure what's its supposed to be. It shifts into drive and reverse no problem not hard or nothing. Also can hear it shift into first when I shift it manually all the way to 3rd it's like it's not being told to shift. Any help or ideas? Thanks
Friday, July 10th, 2020 AT 4:02 PM
  • 108,179 POSTS
The only code you have that pertains to the transmission is the 39. It indicates the ECM is seeing engine RPM's at a higher rate than it should be at a given time after the torque converter clutch is engaged.
Here are diagnostics that are related to identifying the cause. All attached pics correlate with the directions.
___________________________________
See Pic 1 for schematic
The ECM completes circuit for TCC solenoid by grounding circuit 422. Grounding this circuit allows solenoid to energize and supply oil pressure to torque converter clutch. Code 39 indicates that ECM is seeing engine speed at a greater RPM than would be expected at 55 mph with TCC engaged. Possible causes of this condition are:
a. Defective TCC solenoid.
B. Defective TCC brake switch.
C. Defective wiring or electrical connectors.
D. ECM not able to properly process signals.
To diagnose a Code 39, proceed as follows:
1. Turn ignition on and connect test lamp between ALDL diagnostic connector pin F and ground.
2. If test lamp lights, proceed to step 3. If test lamp does not light, proceed as follows:
a. With ignition on and brakes released, check for voltage at both sides of TCC brake switch using a test lamp.
B. If test lamp does not light on either side of switch, check GA-TRANS fuse. If fuse is blown, replace fuse and repair ground in circuits fed by fuse. If fuse is not blown, repair open in circuit 3 or 39.
C. If test lamp lights on one side of switch only, check adjustment of TCC brake switch and adjust or replace as necessary.
D. If test lamp lights on both sides of switch, disconnect transmission connector and connect test lamp between pin A and ground. If test lamp lights, proceed to step 2e. If test lamp does not light, repair open in circuit 420.
E. Connect test lamp between pins A and D of harness connector. If lamp does not light, repair open in circuit 422. If lamp remains lit, check for loose transmission connector or open circuit in transmission.
3. If test lamp lights, proceed as follows:
a. Enter diagnostics and display Code.9.6. If test lamp remains lit, proceed to step 3b. If test lamp flashes in three second intervals, proceed to step 3d.
B. Disconnect transmission connector and measure resistance between pins A and D on transmission side of connector.
C. If measured resistance is less than 15 ohms, repair short in transmission circuit and verify that ECM has not been damaged. If resistance is greater than 15 ohms, check circuit 422 for an open. If circuit is satisfactory, check for faulty ECM or ECM connector and repair or replace as necessary.
D. Start engine, enter diagnostics and display parameter.1.2.
E. Drive vehicle at 55 mph. When TCC engages, the ``TCC'' status light will go on and test lamp will go out.
F. With test lamp off, display parameter.1.1 and ensure engine RPM does not exceed the following speeds at 55 mph: Eldorado and Seville except high altitude models, 1600; high altitude Eldorado and Seville, 1700; DeVille and Brougham except high altitude models, 1700; high altitude DeVille and Brougham, 1850.
G. If engine speed exceeds specifications, system is functioning normally and transmission is at fault.
________________________-
I hope this helps.
Friday, July 10th, 2020 AT 6:43 PM
THEROEFAMILY
  • 14 POSTS
  • 4.1L
  • V8
  • 86,133 MILES
I didn't really understand how to or what I need to use to test with. I have a test light that also reads voltage. I tested between ground and what I believe is pin f but it says to go 55. I can't because it wont shift not sure if I am not understanding or using wrong tester. Thanks so much!
Saturday, July 11th, 2020 AT 10:38 AM (Merged)
  • 52,797 POSTS
Good afternoon
What is the exact issue and can you please list the codes for me to see so I can help you?
THEROEFAMILY
  • 14 POSTS
My transmission will not shift out of first goes in drive reverse and shifts easy. It is giving me codes; 19, 27, 39, 52 on the third time just 27 and.0.7 and stays on.
Saturday, July 11th, 2020 AT 10:39 AM (Merged)
  • 52,797 POSTS
Okay, I attached the codes below. I do not see anything in the codes for your issue.
I would suggest the governor may be the fault.I attached the procedure and a picture. The gear I circled is the common failure.
Code 52 indicates that the ``long term'' memory in the ECM has been reset. This will occur whenever power is removed from the ECM. The code should be cleared from the memory after restoring the ECM's power supply. When the ``prom error'' is corrected, the ECM resets its memory and stores code 52.
19
With ignition on, ECM energizes fuel pump relay for two seconds and feeds 12 volts to fuel pump circuit. Unless distributor reference pulses are received within this time, ECM will de-energize relay so that fuel pump will not continue to run with ignition on. Code 19 indicates that fuel pump relay circuit continues to have 12 volts after two second prime. Possible causes of this condition are:
a. Faulty fuel pump relay.
B. Faulty oil pressure switch.
C. Defective wiring harness or electrical connectors.
D. ECM not processing fuel pump signal or not turning relay off.
To diagnose a Code 19, proceed as follows:
1. If unwanted source of voltage can be eliminated, self-diagnostics can be used to detect this by displaying parameter.1.0. When voltage is removed from circuit, ``battery voltage'' reading will drop to 0 volts.
2. Eliminate branches of fuel pump circuit first by removing oil pressure switch connector. If ``battery voltage'' reading is now 0, oil pressure switch must be replaced because it is closing switch without receiving oil pressure.
3. If ``battery voltage'' reading is still greater than 0 volts, another portion of fuel pump circuit can be eliminated by removing fuel pump relay.
4. If ``battery voltage'' reading is still greater than 0 volts, inspect circuits 120 and 120E for a short to voltage.
5. If voltage on circuit 120 is greater than 0 volts when ECM is disconnected, the circuit is shorted to voltage. If voltage reading is 0, fault must be in ECM connector or in ECM.
6. If ``battery voltage'' reading is now 0 after removing fuel pump relay, probe relay socket cavity 5 with a test lamp to ground. With ignition on, test lamp should light for two seconds, then go out. If light goes out, replace relay.
7. If light stays on, either ECM or wiring harness is shorted to voltage. If there is voltage on circuit 465 with ECM disconnected, circuit is shorted to voltage. If voltage is 0, check for faulty ECM or ECM connector.
27
If this code is not displayed during the third pass of diagnostic codes, the problem is an intermittent failure. To help isolate the problem, operate vehicle while observing throttle switch status light. If throttle switch ever fails to close upon release of throttle, investigate circuit for malfunction. Also check for misadjusted minimum air rate, binding throttle linkage or binding ISC plunger.
The ECM supplies a 5 volt signal to pin B of the idle speed control motor. When the engine operates above idle speed, the throttle switch is open and the ECM increases voltage in circuit 427 to 5 volts. When the idle speed switch is open, the idle speed control motor will not control idle speed because engine speed is controlled by the driver. Code 27 indicates that the throttle switch remained open during the last ignition cycle and has not yet closed during the present cycle. Possible causes of this condition are:
a. Defective idle switch.
B. Defective wiring or electrical connectors.
C. ECM unable to process signals properly.
To diagnose a Code 27, proceed as follows:
1. Turn ignition on and enter diagnostics. Observe ``Throttle Switch'' light above ``Lo'' button on ECC control head. If light comes on, proceed to step 2. If light remains off, refer to ``Code.7.2, Throttle Switch Circuit'' diagnosis.
2. Exit diagnostics with ``Throttle Switch'' light on. If Code 27 remains as a hard code, replace ECM. If Code 27 is now an intermittent, refer to note above.
39
Governor
Inspection
1. Remove drive gear from shaft, then inspect gear for damage or nicks.
2. Inspect governor cover for damage.
3. Inspect driven gear for nicks or damage.
4. Inspect governor shaft seal ring for cuts, damage and free fit in groove.
5. Inspect governor weights for free operation.
6. Inspect for damaged, mispositioned or tilted springs.
7. Inspect for presence of 2 check balls.
8. Inspect shaft for damage.
9. Inspect governor thrust washer for damage.
10. If damaged, remove seal ring by cutting it off governor shaft. Use care to avoid damaging groove.
Assembly & Installation
1. If removed, install seal ring on shaft and place seal ring end into pilot hole in case to size seal, then lubricate with petroleum jelly.
2. Install speedometer drive gear on governor shaft. Make sure that slot in gear aligns with pin in shaft.
ImageOpen In New TabZoom/Print
3. Install speedometer drive gear to governor cover-thrust washer, see image, then install governor and speedometer drive gear assembly into transmission case.
4. Install O-ring seal on governor cover, then install cover, making sure governor shaft aligns with hole in cover.
5. Install governor cover attaching bolts and torque to specifications.
6. Install speedometer driven gear assembly, bolt and retainer clip. Torque bolt to specifications.
THEROEFAMILY
  • 14 POSTS
  • 4.1L
  • V8
  • 86,133 MILES
Trouble codes 19, 27, 39. 52 third time around 27 only then 0.7 and stays on that.
  • 52,797 POSTS
Hello again,
Did you not understand anything I posted in your other post?
THEROEFAMILY
  • 14 POSTS
I am sorry I just got the second post.
Saturday, July 11th, 2020 AT 12:11 PM
THEROEFAMILY
  • 14 POSTS
Okay, I have inspected codes 27 and 52 remain on the.0.7 stays on the screen the transmission shifts but is a little hard. Should I be worried about the codes it's still giving me? I think it in the gear shifter itself on the steering wheel.
Saturday, July 11th, 2020 AT 12:24 PM
  • 108,179 POSTS
I noted that Roy has stepped out for a bit. I will try to jump back in. Are you saying that codes 27 and 52 are staying on? Also, what is the.0.7?
Sorry for those questions. I'm trying to get back where he left off.
Tuesday, July 14th, 2020 AT 8:24 PM
THEROEFAMILY
  • 14 POSTS
Thanks and yes 27 and 52 stay on the third time then reads -0.7 until I hit the off button but now the ECC display and mileage center just went blank all sudden yesterday the battery is losing power and if it sits for a while it does not want to crank it just chunks like it does not have enough power to start.
Tuesday, July 14th, 2020 AT 11:03 PM
  • 108,179 POSTS
The 52 just indicates that power was removed from the PCM. If you had anything disconnected, that is the cause. Next, the 27 is specific to the idle speed control. Is there an idle speed issue? Also, the -0.7 still has me lost. Is that something you are seeing in the instrument cluster? Also, and I am sorry to ask this, would you re-explain what is now happening?
As far as the ECC issue, I will need you to start a new thread with that question.
Hope you understand.
Wednesday, July 15th, 2020 AT 2:52 PM
THEROEFAMILY
  • 14 POSTS
Yes, I understand. When it first start it wants to shut off on me, but other than that no.
Thursday, July 16th, 2020 AT 5:05 AM
  • 108,179 POSTS
Chances are the idle switch may be failing. Basically, the throttle remains open rather than closing when the engine is turned off. As a result, it takes a few seconds for it to recalculate. Since it does, I don't think it's a computer issue. In this case, it could be a wiring issue or a switch is bad.
____________________________________
Here are the diagnostics for this code. Take a look through it and let me know if helps. The attached pics correlate with the directions.
1985 Cadillac Seville V8-252 4.1L
Powertrain Controls - ECM/PCM
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection Manufacturer Code Charts DTC 27 Powertrain Controls - ECM/PCM
POWERTRAIN CONTROLS - ECM/PCM
Fig. 21 Idle speed control throttle switch wiring circuit
Pic 1
Let me know if that helps.
Thursday, July 16th, 2020 AT 2:14 PM
