Transmission problem on 1981 turbo Trans Am (4.9L turbo V8) factory stock
AUTOMAN_1954
  • 1981 PONTIAC TRANS AM
  • 4.9L
  • V8
  • TURBO
  • 75,000 MILES
While driving a steady speed of about 50 mph the transmission acted as if it was shifted into neutral. I had to drive 1/4 mile in reverse to get home. The next day I started the car to let it warm up, checked the trans fluid level and it was perfect. I put the gear selector into drive and you can feel it engage, however when I took my foot off the brake the car did not move. I pushed the gas and still the car did not move. Shifted in reverse and the car moved, shifted into low ( first gear) and no movement. Same in all forward gears
Do you
have the same problem?
Wednesday, December 24th, 2014 AT 8:44 PM
HMAC300
  • EXPERT
Sounds like rebuild time see a trans guy
Thursday, December 25th, 2014 AT 5:31 AM
Recommended Guides
