Transmission problem
MICHAELMEIGHAN
  • 1999 CHEVROLET TAHOE
  • 156,000 MILES
My Tahoe keeps burning up transmissions. Ill put one in and drive it for 10 mins and itll burn it up and wont switch or itll slip threw gears and fluid gets black and burnt ive replaced the radiator on it and the cooler lines and put a used computer in it and still the same problem. I don't know what else I could try ive heard it could be a problem in the ignition switch but it starts just fine.
Do you
have the same problem?
Sunday, May 26th, 2013 AT 6:17 PM
CADIEMAN
Are you replacing the converter also?
Sunday, May 26th, 2013 AT 6:40 PM
Recommended Guides
