Transmission problems
MNSTANLEY
  • 2008 FORD ESCAPE
  • 6 CYL
  • AWD
  • 32,000 MILES
When I am driving and either slow down or speed up, sometimes my vehicle will not shift into gear and then it jerks and shifts. I have checked the transmission fluid and it is good.
Do you
have the same problem?
Friday, March 5th, 2010 AT 12:22 PM
  • 108,005 POSTS
This sounds like a turbine shaft speed sensor has gone out but to be sure lets run the codes
Here is the location of the input shaft speed sensor. Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Cheers
Wednesday, May 5th, 2010 AT 10:37 AM
KENDRARUSSELL
Thanks you for this post I got a new sensor for $46.00 the car works great! I love this site.
Wednesday, October 3rd, 2018 AT 4:10 PM
SHARIF98
  • 2005 FORD ESCAPE
  • 3.0L
  • 6 CYL
  • 4WD
  • 119,800 MILES
I found a very nice looking 2005 Ford Escape 3.0L 6 cylinder car on the auction and was able to get the car for $1400 ($1900 including fees). The car was guaranteed to Run & Drive or return the car. We went to get the car and turns out the engine was able to start properly; however, the car turns on Park but when I move the stick shift to any other mode, the car stays on Park and doesn't move forwards or backwards. Two of the people who work there came to see what's wrong with the car, one looking under the hood and one moving the stick shift, and I heard them saying that something moves when the they shift the transmission. The car also has rust above the back wheels. We ended up returning the car for a full refund. The car came back on the auction and we are thinking about spending no more that $600 (or more if it's worth it) to re-buy the car. We also found a good deal to get a whole new transmission system for $500 and we will probably the same for labor. What do you think would be the problem with the transmission? Would we need to replace the whole system? How much do you think would be the cost to fix the rust on the car? I am mainly buying this car so I can sell it for a higher price, I heard that it's very hard to sell this type of car and that it usually has a lot of mechanical problems from a mechanic that my friend knows, Do you agree? Please provide as much detail possible on the transmission problem. Vin# 1FMCU03155KD75895
Thursday, October 4th, 2018 AT 10:58 AM (Merged)
  • 31,938 POSTS
It is impossible to quote any transmission work with out actually seeing the transmission dismantled first, there are so many things that can go wrong with out doing some tests we would be working blind folded, unfortunately this also goes for the body work, sight unseen you just don't know how involved it may be. If you can get a good second hand transmission I would go down this path, I doubt that the panel work will cost a lot, but you really need to get a panel shop to quote this as well.
JOSEPH AMBS
  • 2001 FORD ESCAPE
  • 175,000 MILES
Shifs fine when driving then suddenly down shifts on own and at times into neutral, then when stopped can return driving by shifting up. This is auto transmission 4x4
Check the transmission fluid level and condition if okay -bring it in and have it further checked by a transmission specialty shop-
2CP-ARCHIVES
  • 4,544 POSTS
  • 2003 FORD ESCAPE
  • 200 MILES
Transmission not shifting in drive posistion but will shift if shifted manually
  • 52,797 POSTS
Have the valve body checked as it may be the issue.
DAVE CHANDLER
  • 2003 FORD ESCAPE
2003 Ford Escape Automatic
Automatic gere shifter on the column is locked and will not shift into gear
Get the shift interlock control system checked out-
KCARLTON
  • 2003 FORD ESCAPE
I've noticed that my 2003 ford escape downshifts itself and will not pick up/hold speed like it should. Also, I've noticed that I am able to start my vehicle but not move it at times. Could it be the transmission going bad or could it be something else?
Thursday, October 4th, 2018 AT 10:59 AM (Merged)
  • 52,797 POSTS
It sounds like it is internal particularly with it not moving in gear. You need to have a trans shop check it for you and give you a bid.
PROKUDANOV
  • 2005 FORD ESCAPE
  • 67,000 MILES
The problem Ford Escape 3.0
Battery dead then slipping on the shifting form 2-3 gear.
No DTC codes appears.
Rebuilt with:
- Master repair kit (seals frictions, gaskets, pistons etc.)
- New solenoid body
- New valve body
- New filter and almost all details in pump
- New planetary.
The result: when cold transmission (approx 10 min after start) everything OK
When hot tranny 2-3 slipping, other 1-2, 3-4 soft shift
What is wrong and where to find problem?
Wednesday, November 13th, 2019 AT 10:48 AM (Merged)
HMAC300
  • 48,601 POSTS
It sounds like the turbine shaft speed sensor is not working correctly which may or may not create a trouble code. Here is the location so you can check it out. Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is
PROKUDANOV
The problem that all this done in tranny repair shop with tranny experienced guys. The scanner used for diagnosis is professional from Ford dealer in Minsk (Belarus). The plates are new, three times checked and adjusted clearance between plates. Seals and gaskets are new as well. So I did the senor and the problem is gone thanks for he help I love this site.
HMAC300
  • 48,601 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
CARTOONBOY18
  • 2003 FORD ESCAPE
  • 108,000 MILES
It rolls backwards when I am on a small or large hill when the car is in drive. I was wondering if the tranny is slipping or if their is something else wrong with the gearbox. It has never done this before.
The trans fluid is good and the check engine light is not on.
CARADIODOC
  • 33,699 POSTS
That's normal in any car on a steep incline. You should not feel it jolt into gear when you raise engine speed slightly. If the car doesn't roll backward with a slight increase in engine speed, you likely have nothing to worry about. Just in case though, check the fluid level.
OUTOF813
  • 2005 FORD ESCAPE
  • 4 CYL
  • FWD
  • 56,000 MILES
My car has been running great until yesterday. I was driving and all of the sudden the engine would rev but the car would not move. I shut it off and tried again in a few minutes. It went about 100 feet then same thing. Today I changed the fluid and it was full but black and burnt. I drove ti around for like 10 minutes and ti was fine then it started whining then would not move again. After beign shut off for a few it would move a little bit then same thing. How bad is this? I am optimistic that its not all bad since after time it would work.
  • 31,938 POSTS
Hi there,
The black & burnt oil I a very bad sigh sorry. This is an indication of extremely high temp in the transmission due to band slippage, your trans will more than likely require a full overhaul.
Mark (mhpautos)
