Transmission swap
SANDERS530
  • 2003 NISSAN XTERRA
  • 3.3L
  • 6 CYL
  • 100,000 MILES
Will a 2001 Xterra 4x4 transmission fit in a 2003 Xterra (not a 4x4 )?
Do you
have the same problem?
Tuesday, August 20th, 2019 AT 4:33 PM
  • 52,797 POSTS
Good evening.
Yes, but if you want the 4 wheel drive to work, you will need the 4 wheel drive transmission.
Are you planning on keeping the 4 wheel drive?
Tuesday, August 20th, 2019 AT 4:52 PM
SANDERS530
  • 10 POSTS
  • 6 CYL
  • 100,000 MILES
Will a transmission out of a 2001 4wd Xterra fit in my 2003 2wd Xterra?
Wednesday, August 21st, 2019 AT 11:55 AM (Merged)
  • 108,005 POSTS
Welcome to 2CarPros.
They are two different style transmission. Being one is for 4wd, the housing will be different. Plus, I suspect the internal electronics will be different as well. I only recommend a direct fit part for this. Otherwise, you may end up having TCM (transmission control module) issues.
