2002 Toyota Yaris Squeaking / Whistling?
PLATTSY88
  • 2002 TOYOTA YARIS
Noises problem
2002 Toyota Yaris Manual 65000 miles
Help! My Car has starting Squeaking and recently its whistling, like air is passing through something? This only happens once the car has been driving for over 5 miles and only makes the noise around 25 miles an hour or less and stops when the brakes are put on. Is this a serious problem?
Do you
have the same problem?
Tuesday, May 26th, 2009 AT 4:12 AM
MMPRINCE4000
  • EXPERT
Check for vacuum leaks at the brake booster hose.
Monday, July 27th, 2009 AT 9:22 AM
Recommended Guides
