2001 Toyota Sienna Side Sliding Door
KATIEE2001
  • 2001 TOYOTA SIENNA
  • 6 CYL
  • FWD
  • 125,000 MILES
I recently had to replace my battery and afterwards my side sliding door will not work automatically. I never had a problem with it before. I can only work it manually now. Is there some sort of reprogramming that can be done to fix this problem. I could not find an answer in the owners manual. Thanks
Do you
have the same problem?
Monday, September 1st, 2008 AT 5:21 PM
JMZZLL
Try resetting the ECU with this procedure.
A. The Main Power Switch (located on the left side of the steering column) MUST be
in the "OFF" position (red line not showing on the switch button).
B. Place the transmission selector in "Park" .
C. Make sure the right side sliding door is fully closed (manual operation).
D. Disconnect the 12V negative battery terminal and wait for more than one (1)
minute, then reconnect the negative battery terminal.
E. Turn the ignition switch to the "ON" position.
F. Push the power door MAIN switch "ON" (red line on the switch will be showing)
and wait for 10 seconds.
G. Open the sliding door by pushing either the power sliding door control button
(located on the right side of the dash by the radio or on the "B" pillar) or the
remote switch on the key ring and allow the door to open all the way).
Wait three (3) seconds after the motor stops running before proceeding.
H. Close the sliding door by pushing either the power sliding door control button
remote control button and let the door close all the way.
I. Repeat steps G and H.
IMPORTANT:
Steps G and H, described above, MUST be repeated.
J. Confirm proper operation of the power sliding door system
Friday, October 17th, 2008 AT 1:47 PM
Recommended Guides
