1991 Toyota Previa gear oil leaking
FSMITH43
  • 1991 TOYOTA PREVIA
  • 4 CYL
  • 28,900 MILES
I need to find out what the proper name for the rear seal where my gear oil is leaking out of the front of the rear end. It is where the drive shaft enters the rear end. Is there a likely cause and if there is more than on seal at the rear end
Do you
have the same problem?
Wednesday, May 27th, 2009 AT 9:28 PM
  • EXPERT
Rear pinion seal
Tuesday, September 1st, 2009 AT 8:08 AM
Recommended Guides
