1994 Toyota Pickup truck want start acted like was firing e
BIGED15RED
  • 1994 TOYOTA PICKUP
  • 4 CYL
  • 4WD
  • MANUAL
  • 200,000 MILES
Truck want start acted like it was firing early mechanicly in time changed ignitor an coil ecm now not firing at all pick coil ohms out good by specs that I have but no signal to fire coil
Do you
have the same problem?
Tuesday, February 2nd, 2010 AT 12:21 PM
Hi biged15red, Welcome to 2carpros and TY for the donation
The Ne and G signals has to make it to the computer in order to give an Igt signal telling the ignitor to fire the coil, when this happens the ignitor will send an Igf telling the computer combustion has occured this actions is repeated to each cylinders-I recommed you check these wires from the distributor to computer
Tuesday, February 2nd, 2010 AT 2:37 PM
Recommended Guides
