1986 Toyota Pickup engine stuttering
DYOUNG81
  • 1986 TOYOTA PICKUP
  • 4 CYL
  • 4WD
  • MANUAL
  • 200,000 MILES
I just had the 22R engine rebuilt on this truck and now it has a bad stutter after the engine gets warm. I had someone hook a code reader up and it showed the throttle position sensor, so I replaced it and it ran ok for about 5 minutes, then started doing it again. It will stutter some while idling, but mostly right at 2000 RPMS it will start cutting off. I can spary brake cleaner directly int he intake and it will stop, so I feel like it's a fuel problem. I had the code read again after installing the sensor and it read either TPS again or the main computer. Any ideas? It is fuel injected.
Do you
have the same problem?
Saturday, August 23rd, 2008 AT 5:32 PM
ROB2008
Did you set the tps to specs?
Sunday, September 14th, 2008 AT 10:06 AM
Recommended Guides
