1986 Toyota 4 x 4 167000 miles 22R Engine
DROPER
  • 1986 TOYOTA PICKUP
My son took the truck 4 wheeling and since then the cluch will not work. There is no grinding noise. You can hear the gears shift. I hate to have to put a clutch in. I just put one in about 25000 miles ago. Could there be something else broken that would not allow the clutch to work properly?
Do you
have the same problem?
Wednesday, June 6th, 2007 AT 1:28 PM
A good place to start is with the clutch master cylinder and slave/servo.
Thursday, June 7th, 2007 AT 6:49 PM
Recommended Guides
