2005 Toyota Corolla
SAMEER BEDRUD
  • 2005 TOYOTA COROLLA
Electrical problem
2005 Toyota Corolla V12 Two Wheel Drive Automatic
I have a 2005 corolla car which I bouth it a few months ago. Whenever I start the car in the front board where the lights of engen, bettry and so on apears, a light is on which is wretten MAINT RHQD. I need some information that I should check which part of my car to solve this problem?
Do you
have the same problem?
Sunday, May 10th, 2009 AT 1:33 AM
BMRFIXIT
  • EXPERT
To reset MAINT reminder light after engine oil replacement, turn ignition switch to OFF position with odometer reading showing.
Press and hold down trip meter.
Turn ignition switch to ON position while holding down trip meter RESET button.
Hold trip meter RESET button down for at least 5 seconds. Odometer should indicate "000000", and MAINT reminder light goes out.
Sunday, May 10th, 2009 AT 6:12 AM
Recommended Guides
