Cabin Air Filter?
RMLOWRIE
  • 2009 TOYOTA COROLLA
  • 4 CYL
  • 75,000 MILES
First, I am not certain if I chose the right category, as I am not sure WHERE the cabin air filter IS. Second, assuming it is somewhere INSIDE the cabin, can you tell me how I might be able to replace it, instead of paying a "technician" a hundred bucks to do it for me? Thanks so much, Rob Lowrie
Wednesday, July 14th, 2010 AT 11:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
It is located behind the bottom glove box. No tools are needed on the 2009. Locate the strut on the right outside of the glove box, squeeze the keeper together and slide the strut off, move the glove box to one side to release the side stops, and the pull the glove box off the bottom hinges (it just snaps on and off). You will see a black cover over the filter. Pull the right hand tab over to release the cover and remove it. Replace the filter and reverse the procedure. Here are the instructions in the diagrams below to show you how to replace the cabin air filter. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Wednesday, July 14th, 2010 AT 1:08 PM
TOOLEEY
  • 2007 TOYOTA COROLLA
2007 Toyota Corolla 4 cyl Automatic 20000 miles
Can you tell me where the Cabin Filter is and how to get it off?
Thanx!
Tooleey
Saturday, August 15th, 2020 AT 10:50 AM (Merged)
Its behind the glove box
https://www.2carpros.com/forum/automotive_pictures/12900_air1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_air2_1.jpg
RICEPAT444
Smells problem
2007 Toyota Corolla Automatic
Where is the cabin air filter located on my 2007 Toyota Corolla? How do I change it?
Its behind the glove box-
https://www.2carpros.com/forum/automotive_pictures/12900_filter1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_filter2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_filter3_1.jpg
WES63
  • 2005 TOYOTA COROLLA
  • 4 CYL
  • 63,000 MILES
Which way does the air flow arrow on a cabin filter for an an 05 corolla. One dealership says up and another says down. Thnaks wes
MMPRINCE4000
  • 8,549 POSTS
Check the cabin filter. If there is no "this side up" or a flow arrow, it wouldn't make any difference. In many cases they will only fit one way.
Also check the owners manual.
DASARIKC
  • 2000 TOYOTA COROLLA
  • 4 CYL
  • 65,000 MILES
Please guide me where the air cabin filter is located and how to change it?
Please provide me any links related to this topic
Saturday, August 15th, 2020 AT 10:51 AM (Merged)
  • 31,938 POSTS
Hi there,
to the best of my knowledge, there is a cabin air filter in this model behind the glove box
mark (mhpautos)
NAVY911
Thanks a lot. How can I clean refrigrator it's too dirty!
I couldn't open I just hardly saw it? It looks too complecated to open for deep clean.
Regards.
