Windshield washer motor location
PHIL OWENS
  • 2004 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 95,000 MILES
My wipers work but the washer fluid won't dispense. I have replaced the fuse. Would I need to replace a motor or a pump?
Wednesday, January 6th, 2010 AT 4:08 PM
MMPRINCE4000
  • 8,549 POSTS
It sounds like the pump motor is bad which is common here are the instructions on how to replace the pump motor in the diagrams below. (F5) Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Friday, January 8th, 2010 AT 8:09 AM
PHIL_SCOTT
  • 2002 TOYOTA COROLLA
  • 4 CYL
  • MANUAL
  • 9,500 MILES
How do I change the washer motor/pump
Monday, April 27th, 2020 AT 12:06 PM (Merged)
  • 31,938 POSTS
Hi there,
Remove the washer bottle and the pump is located at the base, its fitted into a rubber seal ring, it will come out fairly easily, (or it should)
Mark (mhpautos)
DAZMAZ77
  • 1993 TOYOTA COROLLA
  • 140,000 MILES
We just got a second hand 1993 Toyota Corolla Seca CSI Limited. There was some problems with the electricals & we got those fixed. Now the rear wiper wont spray & the pump has already been replaced.
Can anybody help us as to what to do?
Monday, April 27th, 2020 AT 12:07 PM (Merged)
KHLOW2008
  • 41,815 POSTS
First thing to do is to check if the motor is buzzing when activated. That could mean the motor is working but water is not getting sprayed due to clogging of lines or leakages between motor and nozzle.
