1999 Toyota Corolla firing order
CJJ
  • 1999 TOYOTA COROLLA
  • 4 CYL
  • MANUAL
  • 163,000 MILES
Disconected wires to spark plug and need to reinstall the wires. Had lost the firing or for this model.
I had changed the sparks but not the wires and had degreased the engine. Water had got into 2 of the spark plug tubes. Since then the car is misfiring. The old cable I just plugged back in according to there size. What could be the problem. What I am doing now is I took the wires off and soaked up a much of the water out of the spark tubes and now am letting it dry. But before I put on the new spark wires and need the correct firing or in say a diagram or explanation. If not I will just reconnect according to size of the wire and how far it can reach.
Do you
have the same problem?
Sunday, July 11th, 2010 AT 11:34 AM
http://www.2carpros.com/forum/automotive_pictures/12900_fo1_2.gif
http://www.2carpros.com/forum/automotive_pictures/12900_fo2_1.gif
Firing Order 1, 3, 4, 2
http://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Sunday, July 11th, 2010 AT 6:55 PM
