1998 Toyota Corolla AC Fan makes noise
SUYOG_11
  • 1998 TOYOTA COROLLA
  • 4 CYL
  • 137,000 MILES
Hi, I am using a Corolla. My A.C. Fam makes noise when I start he FAN. Sometimes it works good.
I need some help to find out what that fan is called and how to replace it on my own.
Thanks.
Do you
have the same problem?
Friday, April 24th, 2009 AT 4:06 PM
MMPRINCE4000
  • EXPERT
There are two fans, disconnect power connector to fan (one at a time) to isolate which fan is making noise.
Thursday, April 30th, 2009 AT 5:33 AM
SUYOG_11
Thanks for the information below.
I would also like to know if I can find any video/diagram on number of screws I need to untight.
I tried getting fan off but I was not successful.
Tuesday, May 5th, 2009 AT 12:38 PM
MMPRINCE4000
  • EXPERT
Cooling fan should have 4 bolts, one on each corner. AC fan will require removing the grill.
Wednesday, May 6th, 2009 AT 7:11 AM
Recommended Guides
