1995 Toyota Corolla noise at extreme left or right steering
BRUCEEDELSTEIN
  • 1995 TOYOTA COROLLA
  • 4 CYL
  • 11,000 MILES
When I turn the wheel to the extreme left or right particularly when parallel parking I hear a light pitched whining sound. Seems to happen more in colder weather. What could this indicate? I do not hear this in normal driving.
Do you
have the same problem?
Saturday, December 13th, 2008 AT 8:52 AM
MMPRINCE4000
  • EXPERT
Inspect the fluid level in PS pump, high and low pressure hose connections for leaks, and belt tension.
If fluid level is real low, then the pump may need to be replaced.
Saturday, December 13th, 2008 AT 9:55 AM
