1995 Toyota Corolla Car won't start
RUDEBOY6326
  • 1995 TOYOTA COROLLA
Electrical problem
1995 Toyota Corolla 6 cyl Front Wheel Drive Automatic
does the computer prevents the car from starting? If its malfuntioning
Do you
have the same problem?
Sunday, December 13th, 2009 AT 6:42 AM
MMPRINCE4000
  • EXPERT
While possible it is unlikely. Try spraying starting fluid in intake, if engine runs a few seconds, then it is a fuel problem. If not, check spark by grounding plug (wire connected) to valve cover bolt, look for a snapping blue spark.
ECM failure will cause ECM to go into "limp" mode, where ECM runs engine off a preset instruction algorithim, It will BARELY run, but should run to get you to a garage.
Sunday, December 13th, 2009 AT 7:53 AM
Recommended Guides
