1994 Toyota Corolla upgrade transmission 4 speed
NESAN
  • 1994 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 115,000 MILES
Hi, I am going to change my transmission because it is not good. Now I want to install a four speed instead of getting a three speed. Is it possible.
Thank you
Do you
have the same problem?
Monday, July 13th, 2009 AT 5:35 PM
MMPRINCE4000
  • EXPERT
The 94 came with the A131L as standard and the A420 (4 speed) as optional.
You would have to get the trans, cables, brackets and ECM from doner car. You may also have to change CV axles and possibly some suspension components, motor mounts due to larger size of 4 speed.
While the 4 speed would be nice, you would be better off with the 3 speed, unless you have the time to install the 4 speed.
Tuesday, July 14th, 2009 AT 9:14 AM
Recommended Guides
